Turbotonner
Hi All,
My MPH gauge has not worked for a little while now but I'm trying to sort the issue, I've traced the problem to the pedo tube really blocked in the lower leg, ive tried roding it out with wire from top and from bottom, from the bottom it goes in about an inch then is hard up on the casing and from the top it goes down about 4 inches. Does anyone know if the little pipe goes straight down then goes 90 degree at bottom or does it have bends or restrictions inside leg? Also what is the best way to clean it out, wire or chemicals ect? Thank you for any info.
