BF150 won't start
Brisa
2007 BF150 dual batteries. I'm a dumb ass. Crossed my battery wires and turned on selector switch. Installed new switch. Had batteries charged and tested both good. Cleaned connections. Checked all fuses and all good. Turned on batteries and all electronics work. Turned key on and gauges work but nothing no lights or beeps but when turning key off the usual roaring sound is heard which always happens when shutting down and I'm told is normal.
Any help is much appreciated
Just adding to my issue. I also have no power to my trim. I was hoping hondadude or someone of his caliper can help.
Check one of the fuses think its red 10 amp on the engine. Did same thing once, and had same result you have fuse took the hit.
Those two positive battery cables ,the big one and the small one, coming from your switch ,make sure you have battery power on the small one where it connects at the fuse box.
