Hello,
Have a recently acquired 2001 BF115 that is getting some much needed TLC.
I have the Helms manual and been going thru the maintenance section, updating filters,etc..
and checking valves,etc..
I noticed something odd today. If I align the TDC marks for Cyl1 as shown in the manual,and
also using a long plastic straw to ensure that piston 1 is at TDC, the small dimple on the alternator
pulley does not align with mark on the engine.
See attached pic, the white handle screw driver shows the current position of dimple.
Is the alternator pulley keyed to crankshaft? If not, I guess its possibly slipped or not installed correctly?
I was looking for another visual mark on the other toothed pulleys, but don't see one, however the manual
does make mention of such mark. Should I be able to see the timing mark on toothed pulley without having to
remove the alternator pulley?
thanks for your help,
chris
chris
