I was on here last season trying to find a solution for the problems I am having my low-hours 2002 Honda BF9.9. I had it serviced after the boat was hauled but we lost 90% of the sailing season. The mechanic found the idle riser tube was plugged. We got launched yesterday, and after about a half hour of running it started failing again, and I ended up being towed back to the mooring again.
Situation: Rhodes *******n sail boat, engine in a well, This is the third engine we have had since we purchased the boat in 1992. The first was a Mercury 6 HP, pull start. We upgraded to a used Yamaha 9.9 electric start, mainly to get battery charging. It was old when we bought it and in 2002 it died. Replaced it with the Honda, because I believed everything I hear about how good it was. Not any more, It is not trustworthy. Our boat is heavy, has a full keel and the mooring field is crowed and there is a strong tidal current. No way am I going to sail through that.
When we first got the engine it was very difficult to start, took many tries each time. It turns out this was only if we had not been to the boat for a couple of weeks. It would not choke itself. After a battle, Honda replaced the stupid electric choke carburetor which cured that problem. (How great is that? No battery, no pull start. Get it?). The next problem was corrosion on the carb which kinked up the accelerator cable. Corrective action was to make sure all the spray from the p-tube got out of the hull. (Could this be the beginning of the current problem?)
Symptoms: Starts ok, then seems to idle for a bit, then starts stumbling, sometimes you can accelerate, others, no. It can be running nicely as a moderate speed, then drops way down, shudders and stumbles, and then returns to normal operation, or it may just die. Then it will refuse to idle, meaning you can not shift gears.
Yes, it is in a well. A very well ventilated well.
Gas tanks were stored clean and dry over the winter. Engine was winterized.
New gas one week ago with Marine Stable added.
New gas filter in-line since the one on the engine is impossible to reach.
Bulb pumps up fine, holds pressure, and does not affect the the problem when it is having a bad spell.
It ran fine for the first half hour yesterday, from the launch area to the mooring. Then after rigging was complete and I was ready for a spin I started it up and dropped the mooring. Just after that, it did a single hiccup. Oh,.... I grabbed the dingy off the mooring, just in case, and decided to stay in the harbor. Over the next 15 minutes it got worse and worse, would be running fine, suddenly drop way down, run rough, gunning it didn't seem to clear it up, pumping the primer bulb was no help. Hatch open on the well, but it is very well ventilated anyway. Almost made it back to the mooring but it stopped again and would not start right away and wind and tide pushed me back to a shoal area so anchored and called for help. The dingy is too tiny to steer the full keel hull. It will go the way the tide tells it.
If clean gas and two filters cannot protect this engine, then this engine has no business being used in a marine environment. I do not think it is ignition, does not behave that way. Am I wrong? Maybe the carb is corroded inside? and needs replacing again? Working on the engine means pulling it from the boat and that takes a hoist. And with the boat on a mooring that means transport to the dock and back. All very expensive and time consuming. What am I going to do?
