I recently purchased a 98 BF 40, motor sat for a while so prior to running it I completed the following maintenance. I did run it with muffs which kind of initiated the maintenance performed.
Changed fuel filter, Spark plugs"checked gap per Honda spec",low end oil, motor oil, oil filter, t-stat, clean all three carbs which were gunked up also replaced carb gaskets. The boat has fuel thats approximately 2weeks old no additive. I ran it for the first time last night, ran great at high rmps but would not idle. Confirmed fuel tank was vented. Primer ball and fuel line are old but no visible cracks or holes. I did not replace the jets, If anyone has any suggestions it would be greatly appreciated.
