Dan, to ask what is the best RPM involves many other relative factors. Your particular hull, and the way in which you load the boat, may cause this to vary some.
Is this semi-displacement hull a true planing hull? IOW, is it actually intended to plane out?
The least water resistance will be at either hull speed, or at planing speed and then some! The "then some" gets the hull at the correct planing attitude with the least resistance for this hull attitude, IMO.
This may possibly be your RPM sweet spot!
I'd double check your WOT RPM. Make sure that it meets your OEM specs.
This means engines in full tune, Tachometers accurate, etc, etc.
Here's the other side of this.
Marine gassers are prone to heavy load detonation.
Just to be clear.... Detonation and Pre-Ignition are not the same phenomena.
IMO, detonation with the SBC Marine Engine is at a greater potential at/near 2,000 rpm, compared to lets say 3,200+ rpm.
Now we need to add the engine build into the equation.
Many of the SBC Marine engines are fitted with the GM style full dished pistons. These pistons are terrible at combating detonation. In fact, they can actually contribute to and promote detonation.
Ignition advance is held back on this engine build to help in this area, but it does not necessarily eliminate all potential.
Detonation can also be self perpetuating....... meaning that once it begins, cylinder temperatures increase. With the increase in cylinder temperatures, detonation potential also increases.
You can see where we're going with this!
Point being..... 2,000 RPM is perhaps a lousy RPM to be putting the SBC under heavy load (such as planing)......... unless the build accommodates for this..... and typically it does not!
Add to this the long duration at which you may attempt to remain on plane at this RPM.
For the record.... GM, and many of the Marine Engine builders and re-builders, have done us a terrible disservice by continuing the use of these full dished pistons that were originally used during the 70's automobile emissions control erra.
They have no place being in the SBC Marine build.
But they continue using them because they are inexpensive, and one piston p/n fits all 8 bores, etc.
These can be upgraded in material from cast aluminum to a Hypereutectic Aluminum alloy, or even forged aluminum.... but the profile is what's wrong with these when used underneath a SBC cylinder head "wedge" area.
As said, ignition TA is held back as their cure for this.
OK... I'm off my horse now!
