Battery not charging
keithh708
I have a mercruiser 60 bigfoot outboard motor on a pontoon boat and it has stopped charging the battery. In doing some research on the matter I'm pretty sure that the problem is with the voltage regulator, the rectifer, and/or the stator. My question is, which is the likely culprit and how hard is it to changet hese parts out myself? Thanks for any help anyone can give.
Right at the battery...you should see 12.5-13.0 volts at idle. Voltage should increase to a max. of 14.5 volts as you increase RPM to 1500.
Just a quick note. I found a blown and melted fuse in line with the voltage regulator/rectifier. I changed it and the voltage regulator/rectifier and everything is working fine now. Thank you very much for taking the time to help me out with this. I really appreciate it.
