P
Peter Cronin
Guest
" Hi. History: engine began s
" Hi. History: engine began slipping in and out of gear forward and reverse. Replaced badly worn cable and adjusted. Still had problem. Discovered that adjustment on shifter arm was loose; stainless steel shim dropped into my hand. Put back into place (what a pain), tightened and shifter worked like a charm for about a month. Then started nudging itself out of reverse (not as much fun when approaching the dock as one might expect).
Adjustment was not dead tight, but not really loose, either.
I think at some point star (lock) washer was incorrectly placed next to spacer, and so is acting as spacer.
I've noticed other Evinrudes of this vintage can have several spacers in this place.
Question: will removing star washer and putting in several spacers fix this problem, or should I just (just!) drop the lower end and replace the dogs and cogs (or whatever those gear-y-looking things are)?
Sure would appreciate your help on this. "
