I have a Volvo Penta AQ131D with starting/running problems. Sometimes won't start at all then go back 30 min. later and it starts. When warm and accelerating under load it will sputter and die. After running a short time and turning off it will not start usually for at least an hour. I have changed the coil, points, condenser, rotor, wires, spark plugs, distributor cap. We have checked the gap and timing and everything is right on. When engine won't start I look inside the carburetor and it is getting lots of gas but when I pull a spark plug it is dry. It seems like the gas is not getting to the cylanders. I have been having these problems for the last year and a half and even the local boat mechanic is scratching his head at this point. I had it in the shop where they lifted the valve cover and everything looked okay. All timing was reset, water pump was changed, distributor reset and carburetor rebuilt. I had installed an electronic ignition but the mechanic took that out again. Any input would be much appreciated.
