Put my 1978 Sea Ray in the water for the first time in 5+years and after an extensive rebuild, had a small leak from a raw water hose that i was able to quickly replace and everything went great, shifted, didnt overheat etc...but I did have one problem.
I had taken apart the tilt mechanism when i was rebuilding everything, cleaned out and regreased everything but it wasnt functioning properly. It runs and goes down until it contacts the outdrive but wont lift at all...if you pick up the outdrive it will go out farther and then hold it up, put the slightest pressure on the outdrive and it just goes back down a bit, as if its grossly underpowered. Any ideas? Did i maybe not put it back together correctly? The way my boat ramp is I will have to put the motor up at least some when launching and retrieving and ratchet strapping it up and then taking it off right before it i put it in is less than ideal haha.
SBC 350
aq280
SBC 350
aq280
