On the last run of the season in late fall, my boat simply cut out on me. With no time to spare or trouble-shoot, I pulled it, winterized as best I could without running it and put it in storage.
In trying to get it going this afternoon, it became apparent that the fuel pump wasn't getting anything to the carb (only a 5-year old mechanical). I chalked it up as an ethanol-related diaphragm failure. As I unbolted it, I discovered it was much worse. The bolt/cam that the lever pivots on had failed or come loose and the lever had become disconnected from the pump. I was able to snag the spring and one small piece of debris with a magnet. Unfortunately, as I did this, I heard the wonderful clinging of other broken pieces falling down into the chain cover. Despite some makeshift magnet snakes and an oil drain out, I was unable to recover any other pieces.
I'm now left with the option of rolling the dice that these pieces will find their way into my oil pan (and stay there) before getting chewed up in the sprokets/chains or yanking the motor and tearing off the oil pan and cover to locate the pieces.
If anyone has any good tricks for strategically directing shrapnel out of an engine, I'll take them.
By the way, there was no excessive wear on either the lever or the lobe to indicate that the failure was to do a bigger issue. I'm actually amazed that the lever didn't get chewed upon failure.
