ALTWIRING 454
wjspsl1
HI... REPLACING PR. ALT'S
HI... REPLACING PR. ALT'S ON 1987 CRUSADER 350 HP WITH NEW SINGLE WIRE 55 AMP DELCO'S.....BOAT HAS ISOLATOR.. HOW DO YOU WIRE AND FUSE THESE INTO THE SYSTEM ....THANKS
"I think your first issue will
"I think your first issue will be mounting them. The stock alt. mount will push the delcos fwd too much. When we did it, we had to mill the mounts.
Electrically, all you need to connect is the battery wire to the stud. you can tape off the other two leads."
