Johnny One Niner
Hello to all,
First time to the site so let me thank you all in advance for the good advise I've already got from you all. I have a BF15A on a small 15' runabout. Not enough motor for the boat but it putters me up and down Topok gorge on the Colorado River so I'm happy with that until I can afford a bigger motor. Kind a poor mans boat but I love it. A '63 Trailorboat.
My question is this:
Doing maintenance on my motor. Adjusting the idle speed. Recently put a tach on it. Reading about the pitot adjustment which is 1 5/8 out factory setting. Checked it and it was about 3+ turns out. I took it up to a mountain lake a few years ago and of it didn't have enough air so I opened up and must have never returned it.
I read a great article on adjusting the pitot. Put it back to spec, 1 5/8 out. says to start it, warm up, put in gear, then turn it one way and see if it speeds up or slows down. then turn it the other way and see if it speeds up or slows down. looking for the highest idle speed.
Where is the idle adjustment screw during this? So I get it to the highest idle speed adjusting the pitot then lower the rpm to the 1100 +- 50 with the idle adjustment screw? Should I have the idle screw high so I can then lower the RPM? I'm not sure which end of the idle screw adjustment I should be at to properly set the pitot.
I did, in fact, lose some top end speed along the way. Thinking this might be the culprit possibly?
I hope that makes sense. Thanks guys and gals!
