95 johnson 115hp fast strike no spark
35smod
Hi I've got a problem with no spark I e ran thru the troubleshooting and my stator is making output but below specs for ac voltage but ohms out fine I have no spark for all cylinders do you guys think this is my issue or the ignition module bad thanks
I should say also that it was cranking well over the 300 rpm and the motor ran fine last year stored it for winter and now have the problem of no spark
pull the plugs and retest. Removing plugs increases RPM and if you get spark look at starter/cables and battery
I checked it now without plugs only have 18 volts ac going to the ignition module still no spark im thinking I have a weak stator causing my no spark please correct me if I'm wrong
New stator now power pack and new optical sensor still no spark even with the kill wire (black yellow stripe) removed I've got a duty cycle signal going to the ignition coils but little to no voltage to them
