joshsopczak
Good afternoon, gentlemen-
I have a 1991 Mercrusier 5.7 with 638 marked on the block's sidewall (motor serial number 0D427250) which did not have a fully successful drain of the block during winterizing due to a mud/rust dam. I've done a THOROUGH JB weld repair and suspect it will be successful, but won't know for another couple weeks until I can run it on muffs for 30-60 minutes in the driveway to get it heated up for a while and then check the oil. As a secondary plan to make sure I'm ready for fishing season, I saw a 1992 LT1 4-bolt 350 block for sale local to me that looks pretty good. My mechanic friend indicates I should have no trouble using that for a swap, since I'm going to strap the heads and all my Mercrusier gear to the new engine, saying the only differences are in the oil pan and exhaust manifold areas, for which we'll be using the existing. However, the seller is concerned that the LT1 may not be a swappable block for the 638 version of the 350 I have.
I'm looking to see if anyone can help clarify for me the differences between them (if any) for the block and pistons, or if this should be fine to use as a replacement for my cracked unit. To clarify again, I'd be using my existing heads, alternator, pumps, starter, and all other parts, other than the lower half (block, cylinders, and related).
I appreciate any guidance.
Josh Sopczak
Racine, WI
Josh Sopczak
Racine, WI
