marvin1952
This engine set for sometime. how long don't know I recently bought boat. Engine cranks ok but will knot idle very long goes dead. Also after pushing in the choke a few times and raising the trottle it will take off and run great. when you come back in after a prolong idle the engine will go dead and you have to start the process of cranking and fast idle all over. I have run 3 can of Seafoam and pulled the idle screws along with the bole drain screws and sprayed carb cleaner the idle jet holes and the midd range air orfices. I seamed to have cleared up and then it has stared again. Do I need to pull the carbs or do I have weak fuel delivery at low speed. I need advise
Mt
Mt
