The 9.8A3 is a mature design. In order to make it "high thrust", there are two different 4-blade props, a 7 pitch and a 5 pitch. That configuration is typically used with a very heavy load (such as my 8,000-pound sailboat), or a service-type barge. Those props are not usually used for a fishing kicker, unless it's otherwise impossible to slow the boat down to proper (2 MPH) speeds without resorting to idling. The 9.8 is very quiet, efficient, and the lightest weight in its class. It's so quiet that on some motors, you can actually hear a "whine" sound at around 2,000 RPM, that is actually an intake harmonic. You'd never hear that on a louder motor, because the mechanical sounds of the motor would drown out the intake whine. Being a 2-cylinder, it's pretty smooth, and has crisp throttle response once fully warmed up. Like any 4-stroke, the harder you run it, the better it runs. Also (again this holds for any 4-stroke), extensive idling, especially when not broken in yet, and particularly in very cold water, may contribute to "making oil". It is important to run the carb dry at the end of the day (like any motor running on today's junk fuels), or risk varnishing in the carb. We have had very few warranty repairs on the 9.8. It's my favorite Tohatsu 4-stroke design (and the one I have on my personal saiboat).
