Snapper Fisho
Hi all, to those familiar with the 9.5hp bubble motor, I wanted to ask about the carby on our 1966 sportwin. I overhauled it with a new kit as the original float and needle needed replacing. When I pulled it apart I noticed the brass holder of the float arm where the pivot pin goes through has some play movement. There are two round rivet pins that attach the holder to the carb body but I was a little surprised seeing these not tightly riveted to the body and the bracket loose. All other carbs I have in Johnson/Evinrude, the bracket that holds the float arm is part of the carb body. and there is no play.
I find that if I press the primer bulb a bit too firmly once it hardens a little bit of fuel will come out of the breather hole of the carby indicating the needle is not fully closing but it is a brand new seat and needle. Once it starts and runs there is no fuel overflowing and it is fine. It only happens if the primer bulb is pressed with a bit of force. Never a problem on other outboards I have. Could the loose float holder bracket be the cause of this? Seems like it may have been manufactured like that. Should there be no play in the holder? The rivet pins holding it are not able to be tightened or pushed in further. Thanks
