Hello guys and gals. I'll try to condense this and supply a link to a short video. So, this boat sat for a few years but it was covered. Took it out last year and it ran pretty well. However, iin the water it tilted and then went back down on its own. I asked my friendly boat mechanic and he said top off the fluid. It seemed to fix the issue. First time this year last week I was taking it out and the tilt went up but will not trim. It's not the normal not running solenoid or relay issue. Or it seems logical to me its not. It hums both directions but will not lower. I have checked fluid. Topped it off. Removed lines on the bottom and drained it. Refilled and tried it again. Same issue. I can stand on the motor and it will go up and down as you can see in my video. I did that many times hoping something would magically fix itself. I can turn the release pressure screw and it will lower. It makes a screeching noise occasionally that tells me its getting air or has air in the lines but one would assume it would eventually raise the motor. I checked the fluid level after standing on motor and forcing it up and down and the fluid did look very bubbly. I'm hoping one of you have had this issue and repaired it in your past. My best guess is the lift rod, don't know if its Showa or Prestolite rams, has a bad o-ring that allows it to not seal as it should when it lowers or tries to lower. However, logically, I can't understand how it doesn't affect the lift. It does look like only part of the very top of the o-ring between the shaft and the end cap. All of my knowledge is from diving into anything and not knowing my limitations and youtube. Thank you in advance!! jer
https://drive.google.com/file/d/1UbaznTb-VxTe89b3_zEJHCHZ4AO1T6oc/view?usp=sharing
