rob60 sounds like I have the same problem 97 7.4 bravo 3 runs great planes out just want turn over 3300 rpm was turning 4600 last season help please1999 7.4 with bravo 3 will not make power. Will not go above 3700 rpms under load. Not a prop issue, compression is great, plugs are new. Fuel filter changed a week ago.
Intelleq
[h=2]Re: Mercruiser 350 MEFI power issue help needed (2000 Maxum 3300SCR)[/h]Turned out to be an intermittent electrical connection between 2 of the injectors and the wiring harness. The injectors appeared to be firing normally at idle and low RPM but were misfiring or not firing at all at higher RPM. The fix was simple, clean the connector contacts.
