Hi, new to the forum and appreciate the help in advance! So, here's my question,
I have a 1997 Larson 226sei for about 6 years now. Since I bought it, it has had a 5.7L Volvo Penta V8 (which I believe is a 1987 block), with a Volvo Penta SX Cobra outdrive. At the end of last summer, the Volvo engine took a dump. I pulled the engine and had been waiting for another engine to pop up for sale. I ended up seeing a good price for a 5.7L Mercruiser (which I believe is a 1977 block). Based on the fact these are both GM blocks, I figured any problems I ran into I could unbolt accessories from the old Volvo, and swap on to the new Merc. That had generally been the case until I got to the drive coupler. When trying to place the Volvo coupler onto the Merc crankshaft, I unfortunately found out the stud pattern was different and they were not compatible. They both have 6 studs, but the spacing is off between the two. This leads me to my first question. Does anyone make a drive coupler that will mount on the Mercruiser crankshaft that is compatible with my SX Cobra outdrive?
From there, as I felt stuck, out of curiously I tried to slide the drive shaft off of the Merc onto my Volvo SX outdrive, and it slid on perfect. I was under the impression that that should not fit? So, I got excited and thought I got lucky and could re-install the Merc drive couple back on to the new Merc engine and would be good to go. However, I took some quick measurements and realized the Merc drive coupler sits 1.5"-ish closer to the engine than the Volvo's coupler did. As the drive spline off the outdrive in only about 2.5", I would almost have no engagement. This leads me to another question, 1.) Does anyone make "spacers" than I could put in-between the flywheel and the drive coupler to set the back face of the coupler 1.5" to regain my engagement? Or is there any other similar slick way to make that Merc coupler work with the different depths?
I feel like I can't be the first one that has tried to get a Volvo outdrive going with a Merc engine but I've struggled to find anything on it.
Thanks!
Thanks!
