turbosonly
"Prior to the the abovemention
"Prior to the the abovementioned changes, the engine started and ran fine UNTIL the secondaries were opened (under load). Then, it would bog down and RPMs would fluctuate.
Since the boat had been sitting with very little use for a couple years (before i got it), I decided to get the QuadraJet rebuilt. The engine shop who took the carb in for the rebuild asked about the fuel pump as well. I showed them pictures and they recommended a HP Elec Marine Fuel Pump by Carter.
I put the rebuilt carb and new fuel pump on the engine using the existing electrical connections. I ran the pump for a while prior to hooking it up to the carb to make sure clean gas was coming through. After that, i hooked everything up and cranked it. Once started, i noticed a waver in the RPM at idle. It would go up and down 150-200 rpm rhythmically. I also noticed the smell of raw gas at the exhaust. Under load it would stall out. The engine also seemed to run rough.
Now, with 20/20 hindsight, i know i should have done one thing at a time, EITHER the new fuel pump OR rebuilt carb.
Any input would be greatly appreciated."
