hi, i dont have the fuel presure the diacom just test the fuel injector, the fourth first injector i can test them on the scanner the progress test goes up to 100 per cent but the last fourth i cannot even test them .
best regards
Hey guys, i happen to notice the O.P didou posted some additional engine information to an six year old thread over on Offshoreonly forum that is not getting any response to it, So I figured i should copy and paste the additional information here for him/us to work with.
It appears to me he has low battery volts at 11.11 volts.
With this new information, we probably should suggest a new proper size battery to start with, then check for spark, fuel pressure, etc.
2. PERFORMANCE DATA
Parameter Description Value Unit
Engine Speed.......................................... 0 RPM
Available Power..................................... 100 %
Coolant Temperature............................... 75,20 °F
Fuel Flow Rate..................................... 0,00 GPH
Port Exhst Cool Temp.............................. 32,00 °F
Sea Pump Pressure.................................. 0,00 PSI
Starb Exhst Cool Temp............................. 32,00 °F
IAC Duty Cycle..................................... 0,00 %
Manifold Absolute Pressure........................ 14,57 PSI
Trim Position...................................... 1023 #
Baro Pressure..................................... 14,57 PSI
Trim Volts......................................... 4,99 VDC
Manifold Air Temperature.......................... 78,80 °F
Pitot ADC............................................. 0 #
Oil Pressure....................................... 0,54 PSI
Paddle Wheel.......................................... 0 Hz
Throttle Position.................................. 0,00 %
Sensor Power....................................... 4,99 VDC
Throttle Sensor Voltage............................ 0,64 VDC
Lake/Sea Temp..................................... 32,00 °F
Spark Advance...................................... 8,00 DEG
Fuel Level......................................... 1023 #
Battery Voltage................................... 11,11 VDC
3. TROUBLE CODE STATUS
Current ECM Codes
Sensor Fault, click Read Fault button for details
Trouble Code List:
PITOT CKT LO Code is active
FUEL LVL CKT HI Code is active
STEER CKT LO Code is active
SEA TMP CKT HI Code is active
TRIM CKT HI Code is active
there is pressure on the fuel pump the startor good spark plug new the fuse good thank you to help me
best regards.
Above source,
http://www.offshoreonly.com/forums/general-q/138970-350-mag-goes-into-guardian-mode-help-please.html
Didou, The reason you are able to test only 4 functions of the fuel injectors with the scan tool is beacuse the injectors fire in banks of 2, not individually like a sequential fuel injection system, so this is normal, But it's also an inefficient test procedure without a fuel pressure gauge hooked up to help calculate the fuel drop amount within the time frame you set it for.
It's pretty important to know how much fuel pressure you actually have at the fuel rail?
