I have a 33hp 1969, that is having an issue with the spark on one of the cylinders. There is a black wire that is hanging by the vacuum switch, and when it is left alone there is yellow/weak sporadic spark. When I connect it to the vacuum switch, it stops all spark on the bottom cylinder. The top cylinder has spark 24/7 and its strong. I cant find a wiring diagram anywhere, Replaced the coil thinking it could be that, but no change. Thank you for any help!
