Fish Stix
I used to have a Luhrs with a single 360, now I have a Trojan with two 318's - all was well until...
I took the Trojan out after setting idle(s), installing new FWC riser gaskets, and a few other minor things (rust removal and paint). Boat ran fine on the way out, but at 2500+ RPM, the port engine went to 200 degrees. I dropped back to idle and watched the temp go back to 160 degrees. Throttled up again and same thing happened - within a few minutes. Limped back to port at 1000 RPM. I then noticed a little steam coming from port exhaust at idle and above - not much at all, but just enough to be noticed.
I checked oil for water (none), antifreeze levels (no change), temps of the headers at idle (OK). Tonight I did a compression test with all plugs out (all were tan / brown and a few black). All were 120 psi to 140 psi EXCEPT #5 at 60 psi and #3 at 80 psi.
Going forward - I know I need a head gasket - but perhaps someone can enlighten me...
Which happens first - head gaskets don't fail for the heck of it, right? Did I over heat the engine and cause the failure? Or did the head gasket fail and cause the over heat and steaming issue?
Why would the head gasket fail and cause the two mid block port side cylinders to drop pressure?
These are fresh water cooled center risers (not the log type) - is there a potential for trapped air causing the over heat? Do I need to bleed the air out somehow?
While I have the one head off - is it best to change the other head gasket too?
Should I change the freeze plugs too? The motor is from 1975!
What's the standard "while you are in there" preventive maintenance that can be done?
Many thanks for reading all this and any input offered. I replaced a head on my old 360, and while not fun, it was pretty straight forward - any insight offered will be appreciated!
Brooks
Sorry for the barrage of questions!
Brooks
