Will do. Thank you for your input.I have the same start up procedure as you, by the time the self check beeping is done my fuel pump has pressurized the fuel system. I don’t hear the fuel pump over the beeping. I THINK the fuel pump is controlled by time from the ECM. Put a long handle screwdriver on the VST and the other end to your ear while starting, you should “hear” the high pressure pump pressuring up over the noise of the beeping. If the fuel pump is finished pressuring up before the beeping is done then check the starter.
