duo_prop_dad
"290 DP transom mount is being
"290 DP transom mount is being swapped out and when I remove collar and then nuts from inside transom, what will support the aft of engine?
V-8 AQ271c (gm 350)
Appears that engine has two forward mounts and transom shield actually supports back of engine???
Also, does anyone have the #'s of the two bearings and seal to replace in the bellhousing tailpiece?
(So I'll have them on hand and not have to wait)
( I intend to purchase from a local bearing house)
Thanks, john"
V-8 AQ271c (gm 350)
Thanks, john"
