Hi all,
First of all, sorry for my bad english .. I'm french.
I have an issue when shifting into gear Neutral to Reverse or Neutral to Forward. It's not operates smoothly when the remote control lever is shifted from Neutral to Forward or Reverse. I have checked each part separately and don't find issue ... I will probably change the current cables for cables PREMIUM POWERMATCHED. Some advice about this kind of cables?
In addition when re-installing the lower unit, I certainly missed the Neutral position and the Reverse is no longer accessible, but the Forward is OK ...
Do you think the shift rod push arm tool number 90890-06052 is necessary to doubtless find the neutral position or a common pliers is enough?
I screwed up and have to reinstall the linkage correctly. If you have some advise, tricks about lower unit mounting, please let me know...
Thanks in advance.
Thanks in advance.
