This is a 50hp ELPT EFI 4 cylinder, built in 2010 according to the model/serial number sticker. This motor was brand new on my pontoon bought in 2011, no problems until now. Always used in fresh water.<br>
<br>
I turn the key from off to "Run", everything beeps a couple of times the way it always has. I turn the key to "start", the starter motor turns just a little then stops. I see the bendix gear engage then gradually disengage indicating the starter motor is not applying pressure. If I let go of the key and try again, the same thing happens. If I hold the key in the "start" position for a few seconds, the starter will kick back in and spin the motor to start it right up. Very occasionally it will start up properly. Once running, the motor runs fine at all RPM, pushes the boat the way it always has, just keeps on going.<br>
<br>
Battery is good, fully charged, and I get the same behavior if I have a battery booster connected up. All connections from battery to solenoid, starter, and ground are clean and good. All wiring in the motor is clean and dry, no signs of corrosion anywhere.<br>
<br>
I thought it might be the solenoid, but a new one gives exactly the same behavior; signal wire connector is clean and tight. <br>
<br>
I stripped the starter motor; brushes and commutator are in great shape, I cleaned out the small amount of carbon dust from the brushes. Same behavior.<br>
<br>
If I move the shifter into gear, I get the beeps when I turn the key to "run", but nothing happens when I try to start. This is correct and expected.<br>
<br>
The behavior is as if the signal to the solenoid is there momentarily when I turn the key to "start" but then goes away and returns after a few seconds if I hold the key in "start". I will test this theory tomorrow when I have someone to turn the key for me.<br>
<br>
Is there some kind of sensor that can interrupt the signal wire to the solenoid in these EFI motors? Maybe I will have to break open the wallet and buy a repair manual with electrical component and wiring sections.<br>
<br>
I found a very similar post in the forum dated a few years ago, but with no replies.<br>
<br>
All replies and suggestions appreciated.<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
