Hi all new to this forum
I have a bf30 which had a complete overhaul early last year . My unit was overhauled because of low rpm approx 4200 despite changing rings and carb overhaul , my wot compression then was approx 180 psi. A new block was fitted and i managed to run for the season at app 5200 rpm .
I have only managed a couple of outings this season ,however I am back to square one with the running rpm at around 4500 rpm I have reset pilot screws to 1-7/8 turns and done a few syncronisations but it didnt seem to make much difference to the output rpm.
I understand that my carbs might require cleaned again ,but can anybody tell me what vaccum psi I should be pulling . My understanding of Of 4 stroke vaccuum is that it should be around 18 -21 at idle rpm .the higher the better ,that tells me my rings are good . I havnt yet done a compression test
Can anybody give me some vaccuum figures to compare
Cheers
Cheers
