Well thanks for the advice. I usually use that Chemtool B12 instead of Seafoam, just because it's a little cheaper, but works just as well. Hopefully I let the boat sit up too long without using it. Bad gas can cause problems.The ratio is 1 part of TC-W3 (Two Cycle-Water craft rated, 3rd iteration) or 1 pint of oil to 6 gallons of gas a 1:50 ratio. I use Pennzoil brand I buy in the Walmart Sporting Goods section. While at the store I go over to the automotive section and get a can of Sea Foam and mix the recommended 1 oz per gallon of premix. I haven't been into my carbs for over 10 years and still have no problems. Plugs last forever.
I disconnected the oiler in my 2002 90 and 2002 115 with rhe reason being that my engine sits up most of the year and getting these Merc 2 strokers enough fuel in the carbs to light off the engine after long periods of sitting up has been a problem for me. With the built in oiler, if the crankshaft is turning the oil is entering the fuel hose in the engine.....gasoline not necessarily....and yes I know how to start these engines. This causes hard, usually smoky starts. With premix, the fuel-oil ratio remains constant and starts are much faster and cleaner.
I am 82 and not what I used to be so I mark adjacent to the fuel inlet on the boat to pre-mix so that I don't forget. Have I ever thought about going back (replacing the oil pump gear).....nope.
I totally agree.Well thanks for the advice. I usually use that Chemtool B12 instead of Seafoam, just because it's a little cheaper, but works just as well. Hopefully I let the boat sit up too long without using it. Bad gas can cause problems.
