Hello, I am a first time poster. I bought a 17' Lund and Honda BF90 three weeks ago (both 2004 model). The motor worked perfectly when I tried it out.
Fast forward to this past weekend and I took it out for the first time. The motor always cranks, always idles well, and puttered out of the no wake zone with ease. When I went to put it on plane the first time the bow rose up, tach went to about 3,000 and then the motor would rev and the bow would drop. I watched it one time rev from 3,000 to about 4,500 even as the bow dropped and speed decreased.
At first i would back off the throttle but as I kept trying it I discovered I could keep the throttle open and the motor would eventually catch up and the boat would plane. Once on plane it would run all day. After this, I noticed it planes normally about half the time and half the time it does not. If I put it in neutral I can open it up to 5k rpms easily and it doesn't stall.
I called the local Honda dealer down at the NC coast where I was and he thought it was a small drop of water in the carbs. He suggested I disconnect the fuel line and run the motor up to about 3k rpms and let the motor suck all the fuel (and any water drops) out. He said the water drop may only show up under torque. I did that and also drained the carbs with the drain screw and re-launched but same issue. The gas tests fine and fuel lines tested fine.
I am thinking it may be the beginning of a spun prop but not completely spun. When i put motor in gear (motor is off) I cannot turn the prop by hand.
The final confusing point is I went to trailer the boat and when I pressed the throttle quickly the motor sputtered almost off. I have read that the older carbureted BF 90s were set lean and would die down if you opened the throttle too quickly.
Any ideas if this is a complext carburetor/fuel problem or just the beginnings of a spun prop? The boat was garaged about 5 years without use before I bought it. Thanks for any thoughts!
