So I have water leaking from the center of the engine. It is coming out of the seams at the upper and lower cowlings. When I removed them and hooked up the hose to the water flush intake fitting the lower unit fills with water and then it flows across the base and off the edge. I turned the hose on low pressure to see what was going on but if I turn the pressure up it will come out of the telltale. Thanks for any help. I'm not running the engine until I know something. Scott
