boathead1012
Greeting from a four stroke newbie,
Need expert guidance, Bought 18' center console with a 2004 90 with a known engine problem ,water in the engine oil. I have searched the forums and tried to educate myself on this rig. The boat runs and starts fine, has low but even compression across all 4 cylinders (90 -92lbs), plugs look normal, rig seams to have been well cared for until very recently.
Oil was like a milk shake when dropped cold. (no separation). Thermostat was stuck in the open position and flow valve by thermostat was clogged shut. The thermostat housing is in good shape. It has a new starter installed so I pulled that and found the inner housing to appear normal with no signs of water/rust so I think I can rule out he crank seal.
The prior owner was not mechanically inclined. He had been doing a lot of trolling in cold water prior to the problem coming to light. The boat was boatel kept but always used in salt. He told me a shop did the compression check and did 2 oil changes and still got water in the oil.
I am currently waiting for a new thermostat and seals. Could this really be the cause?????
I am thinking the cause is gasket/seal failure due to age. If the thermostat cures it LUCKY ME. If not what is the most likely place to start looking, pull the head (water/oil jacket) breach or the complete power head (gasket/tube grommet). This is were sage expert advice (been there done that )comes in. Any advice greatly appreciated .
Cheers Carl
Cheers Carl
