Bustedknuckle
I have the 03 BF200, all plugs have been replaced, I can't get the motor to throw a code or buzzer while on a garden hose. On water when the light blinks every 5 seconds along with a buzzer I just shut it down and start it back up and no lights or buzzer. However, the code is still in the eeprom. The motor runs strong otherwise, when it doesn't have the MIL light you can never tell something is wrong with it.
1) BIG CONCERN- I have had a hard time getting the bottom two cylinders plugs out and the port side bottom cylinder plug had rust looking particles on it. I cant get a compression tester or a leak down tester to thread into the head of the bottom two cylinders (port side is the worst) so I can't get a compression test on the bottom cylinders.
http://www.pensacolafishingforum.com/f23/spark-plug-reading-586090/
before replacing plugs I got this MIL light code. What code is this?
https://www.youtube.com/watch?v=4OtbZRSS1KM
2)I replaced the plugs but after running for 15 mins or so I got the following engine light. one flash every 5 seconds. Is this a 02 sensor code for engine missfire?
https://www.youtube.com/watch?v=asM3MJUQOnk
*replacing the plugs did seem to help but code still came up.
3) Don't know if this is related but it takes me two times of cranking the motor over to fire up from being cold. Also sometimes the motor seems to be missfiring trying to get to an idle. This only happens sometimes. Hot restarting is no problem.
4) *BIG CONCERN* Looking at motor, the left exhaust port (Port side) has significantly less pressure coming out of the port at idle compared to the right side (starboard)
What I believe started this is, last year before I was getting this MIL light, I was out in the gulf in 4-6 ft seas and while anchoring I got the anchor line caught around the lower unit next to prop, so I was then taking in water from the stern as waves were coming from that direction already and I was basically getting sling shotted to the wreck I was anchored on. Cut the anchor line , scary experience. However, Since that I have been having this MIL light issue.
Any help is greatly appreciated. Thanks for your time!
