Now I'm really confused. My compression readings show 210,210,210,175 for cylinders,1,2,3,& 4. Cylinder 4 checked at 175 psi cold, 175 psi warm and increased to 185 psi after I added 2 squirts of oil to the cylinder, which I believe indicates a ring or valve issue on cylinder 4. The leak down test shows leakage around 2-4% for cylinders 1,2 and 4 and I can hear a slight his through the oil filler cap. I can NOT pressurize cylinder 3. Cylinder 3 will not hold any pressure and it's leaking 100% through the carbs. I can't get any closer to the motor to isolate it since this motor is on a pontoon boat on a lift and I don't have a trailer.
How am I getting 210 PSI of compression on cylinder 3 when I can't get it to hold any pressure for the leak down test, not even 10-15 psi? I've read a leak through the carbs would mean something bad on the intake side, intake valve, seat, etc.
The motor actually sounds like it's running good, but I have not taken it out on the water. I wanted to try to figure out was possibly wrong with the motor I case it was bad enough that I should quit running it and work on fixing it instead.
