2001 Evinrude 10hp 4 stroke new fuel primer
GregGru
My old primer (0427327) had 1 port with hose to top of carb. The new one (5007356 replaces the old one) has 2 ports. Do I just seal off the other port?
Those primer valves are very reliable / simple.-----Why did you replace it ?----Yes you block off the one port or swap the cover over.
Yes. And fuel is coming out now. I just wasn’t sure if I had to run another hose to like a T before going into carb or just block it off. Blocking it off worked great. Thanks!
