I had a really bad day at the lake. My trolling motor went down first (broken intake valve spring) then my main power went down while trying to get home.
It started with the siren (that siren has saved me a ton of money over the years when kelp covers the water pump inlets). I stopped immediately and lifted the leg to check for weeds. All clear. I fired back up after letting it cool and it went 300 meters before the siren went off again. The tattle tale was working but took a while for water to show up and it was HOT water. I shut it off again and let it cool. Then I tired to limp in at about 1,800 rpm. The tattle tale ran but not at the pressure I'm used too and it stopped briefly a few times. I limped it back to the marina and now I have the leg off in my garage and the thermostat out on my bench. I ordered new ones but they won't be here until tuesday ish.
My water pump impeller looks like i installed it yesterday despite being in the engine for 6 years and the thermostat is black and crusty but it does open when you put it in boiling water. The poppet valve diaphram looks a little brittle but not too bad it is also on order. I am starting to worry that there might be a bigger issue?
Is there anything else that affects over heating?
The boat is well maintained and ran like a top. It is using injector oil like it should be and I am pretty sure i didn't do any damage by limping home because I stopped whenever the siren went off and allowed it to cool.
Thanks!
Thanks!
