2000 150 Ficht
I am currently having a problem with my 2000 Evinrude 150 Ficht RAM Injection motor.
It will start and run fine for about 15-20 minutes. Then cuts off and wont even turn over (Just a click sound). All electronics still work. Then about 30 minutes or so later and it will start and run just fine like nothing is wrong for 15-20 minutes and shuts off again. There is no warning sign that it is going to die. Idling just fine then it's like someone turned the key off. Motor just cuts off.
It's not the batteries, I have 2 and both are fully charged on a Jayco switch.
It's Not the computer overheating, I have checked the water flow through the computer and even placed ice packs on the computer while it was running and it still shut off with the computer cool/cold to the touch.
I don't think its the powerpacks (It has 4, 1 single & 1 double for each side) because when it is running it runs great. No rough idle, no problem getting to higher RPMs and power/throttle response is normal.
Does anyone have any ideas or suggestions what could be wrong?
