2+2 115 HP fuel restriction
Teeb
I have an04 2+2 115hp that idles fine fevs up in neutral big boys under load I have changed fuel lines from tank to pump new primer bulb new water seperater new Inline fuel filter and rebuilt fuel pump any advice would be appreciated
Have you tried pumping the primer bulb when it is operating under load? Two thoughts....It is easy to accidentally disconnect the carburetor linkages while working on the carburetors...be sure all carbs are fully opened at WOT. Also not sure which motor cover you have but when replacing the heavy, one piece cover on my 2+2 it is easy to knock the coil wires off of the coils.
