So we just test drove a 99 pontoon boat with a Mercury 125 2 stroke outboard. It took a minute or 2 and a lot of cranking to get started. The guy had to squeeze the bulb about 10 times or more on 2 different occasions and then it started. A lot of blue smoke for a little bit and then it went away. The boat seemed to idle fine. We idle out of the no wake zone and off we went. I noticed he would gradually bump the speed and hold it there for a few and then do it again and hold it there and do it again and so on. The motor sounded good and seemed to run fine. We went about a mile down the lake total and then we slowed down and turned around. The guy never did go back up through the throttle then. He kept it part way and the motor would throttle up and then come back down all by itself and it would do this back and forth until he would move the throttle lever forward more. Then it would start doing it again. He then tried to just go straight forward with the throttle to WOT and it wouldn't throttle up. It acted as if it was going to stall if he didn't pull back on it. A few times it would sputter also. So before I go and drop $5000.00 on this thing I would like to know if I should run or is this a simple fuel issue or spark issue or what? Any help would be appreciated.
