The "man overboard lanyard kill switch"...it may have tripped. If it is working then check for spark at each plug wire w/a spark tester set at 7/16". It needs to be a blue loud snapping spark. Pull the spark plugs and look at the electrode ceramic. It should be brown. Check cylinder compression w/the plugs out and kill switch tripped to stop the ignition. Check for fuel mix getting to the cylinders. Spray a good 2-3 second blast of WD-40 or spray Seafoam into the carb throats and crank it to see if it fires. If it does then the fuel is not getting to the cylinders.What should I check first?
How old is the fuel? Does the fuel squeeze bulb get firm? Check the fuel filter on the engine. If the fuel pump quit the engine will still run untill the carbs are dry.I sprayed fuel in the carbs and got it to sputter for a minute but she still won't run.
