I called Marine engine and a girl gave me a Solas 5211-099-11 part number. I did some checking and this propeller is 10 spline. I need a 13 spline. The engine serial number is 0G621126. According to the parts diagram on ME a 48-85632A45 is the recommended prop. I did some checking and it not supposed to fit a 1998. Just 99-05. The prop that came off the part # is 48-85632-11. 13 spline. The outside diameter of the prop that came off is 3 1/8" so thats got to be a 3 1/4 diameter gearcase. Is going on a pontoon boat if that helps. I figure this is the best place to get help. Most of you guys have been there, done that. Could this 98 be a year end run and the gearcase fall under a 99? Appreciate any help.
