biglakeboaterguy
I was running boat 3/4 throttle on plane for approx 4 miles with not a problem and suddenly it slowed down and will not rev up or run right past half throttle. It sounds like a rev limiter kicks out 1 or 2 cylinders at that point. No overheating problem, (new impeller, lots of flow) new plugs and it starts and idles all day and runs good to half throttle. The last owner ran it for 2 tanks of gas with no issues whatsoever across a big lake with GPS at 42mph. (he is a friend of mine so I know he is not B.SSS. ing me) I have checked all linkages, throttle butterflies are opening (together) and no obvious wiring issues. The oil injection was disconnected and it is running on mix gas. Quicksilver synthetic 50-1 mix. This was a sudden unexpected event and I put new plugs in to try again with same results. Anyone have some help out there? Thank you.
