Good Morning,
This is my first post on this forum and I'd greatly appreciate any comments on the video in the link below. Specifically, the video is a test run of my 1997 Honda BF90A: new water pump, thermostat, flush and pressure-relief valves. Everything looks OK, EXCEPT I'm thinking that water should be coming out through the center of the propeller. And, I can't really see any water coming out anywhere except the telltale stream. But, its hard to tell for sure because the muffs are spraying water around the bottom of the foot, so there may be some water dribbling out down there.
https://rumble.com/vem8tz-1997-honda-bf90a-no-water-out-the-exhaust-is-this-ok.html
When I run the engine as pictured, the thermostat cover gets to hot to hold my finger on - I don't know if this is a good sign, or a bad sign. Related, when I run the motor with the flush hose connected (hoping this isn't a bad thing to do), the thermostat cover stays cool. My concern is whether the water is completely circulating inside the motor. Although, when I opened up the thermostat and relief / flush valve passages I did not see any obstructions - just ordinary light corrosion.
Is it safe to take this out for a test run?
