Thanks for the reply do you think that the motor can be repairedFirst off you should start your own thread with all your motor information and your problem. By the sounds of it your motor is probably done. You should of been checking it out right away when you heard the alarm not just thought it's just a faulty sensor and kept driving. Probably a very expensive mistake.
Everything can be fixed. You need to find out what's going on first. Might be better off just getting another motor.Thanks for the reply do you think that the motor can be repaired
