bradandrose
I've got a 1995 Penn Yan Avenger 232 hull that came with a Alpha One Gen 2 outdrive. The original transom adapter is installed but when I enter the serial number stamped on the transom adapter (0F537504) on the Mercury Parts website, gears for all available gear ratios are listed so I can't tell what the as-built gear ratio of the original gear case was. Does anyone know what outdrive gear ratio would have come from the factory in this boat? Prop info would be helpful too. I'm not finding any detailed specs online.
