I have been lurking on here learning about my new to me outboard. I have read the posts regarding water cooling on fuel pump with interest. I have a hose running to the cover plate of the pump from a fitting on the block in line with the top cylinder about 3" or so from where top carb bolts on. There is no zip ties on the hose and when I removed it no water seen so not sure if this is what folks are talking about. I also read to relocate tell take from bottom port side of block to top cylinder. I have a brass fitting there near the top which could be used and I'm thinking the bottom fitting currently used is plastic so thinking might be better to simply plug it rather than try to remove an old plastic fitting. Am I on the right track here folks? Thanks
