I have a 1995 Glastron 17’ with a 1995 Johnson SPL 112hp with oil injection. Boat trailer and motor in excellent condition and nearly cosmetically perfect. Never in salt water, properly winterized every year and stored in enclosed unheated shelter every winter. Always kept in a garage over the summer except when trailered to the lake. Engine was idling rough when hot, and professional marine shop found #1 cylinder has a cracked ring and slight scoring (note: carbs have all metal bowls – not plastic, so this was apparently not the cause of the idle problem). Compression: Cylinder #1 was 70, #2, #3, #4 were 130+.
The question is: Is this engine worth repairing? I consulted 3 shops. All quote $2,500 to $3,000 for the repair. The first shop recommends new piston, rings, and re-bore for only the bad cylinder, and a new fuel/oil pump. The second shop recommends new pistons, rings and re-bore for all cylinders. The third shop recommends pistons, rings, and re-bore for only the bad cylinder, and new rings only for the other cylinders along with a new fuel/oil pump and new water pump. 2 of the 3 shops don’t think it is worth the expense to repair at all. I really like the boat and motor combination and am leaning toward repairing the engine.
Any recommendations and comments are appreciated.
