Chinatown317
Not sure how to do this w/o telling all details
95-96 Intruder 150
Ran rough when i first purchased the boat, 88 Bumble Bee V178
New gas, new trim blinker
Had to adjust the motor height on the jack plate, got it to plane off and ride smooth
Top speed 50 mph
Then, near top end, bogs out 2-3 trips in a row
Then, runs perfect for a 15 mile trip. Runs great back to the ramp.
Next trip, bogs out at 40 mph, loses horsepower.
Mechanics suggest new fuel line bc the primer bulb was collapsing! New fuel line installed from the tank to the motor.
Fuel filter cleaned
Next trip, bogs out same. 40 mph, loses power. Roughly same amount of gas in the tank every trip. Did try running w the gas cap off, same result of bogging out!
Replace Champion spark plugs w new Champion spark plugs, QL78YC
Checked compression in all cylinders, 100-115 psi
Rebuilt all 6 carbs, gaskets and floats/pin
Took the boat out today, 50% quieter...... soooo pleasant!
Gas'd on, planed off nicely, ran to 42 mph, 10 seconds or so in, bogged out exactly the same way as it has in the past!
I can run it half throttle about 25 mph and it runs smoothly but after that, she is sickly!
Any and all info or suggestions are much appreciated!
95-96 Intruder 150
Top speed 50 mph
Fuel filter cleaned
